Transmission Rattle
Old Sep 13, 2004 | 07:50 AM
miketriton's Avatar
Transmission Rattle
Does anyone out there know what might be the cause of a rattle which seems to be related to the transmission. I notice it when I go thru a drive tru. With the truck in Drive, there seems to be a rattle while the truck is stationary. As soon as I put the truck in neutral, the rattle goes away. I havn't really tried in Reverse as the people in line behind get nervous.
Do I need to go see the dealer or is this normal? 33,000 miles now.
Old Sep 13, 2004 | 09:05 AM
HorseHauler's Avatar
is it a rattle inside the cab, explain a little bit more about it. if its what i had when i put my shifter into drive 2 or 1 it would make a horrible rattle sound in the cab, i checked under the hood and the transmission dip stick was rattling against the ac tube thing. i just added another plastic tie around it and tightened it up and it fixed it. hope this helps
eric
Old Sep 13, 2004 | 09:07 AM
miketriton's Avatar
No the rattle appears to be coming from the transmission. It is especially obvious when parked next to a wall that reflects the sound.
Old Sep 14, 2004 | 04:43 AM
Casey Balvert's Avatar
There was a TSB out on that a while back. They replace the clutch disk with one that has different dampener springs. It won't hurt anything but some find it annoying. I left mine like it is.
Casey
Moobesor
May 31, 2008 01:13 PM
c5r
Jul 22, 2006 06:52 PM
mrbluegrass
May 11, 2006 07:56 PM
jnaker
Jan 18, 2003 07:43 PM
