Transmission Rattle
Does anyone out there know what might be the cause of a rattle which seems to be related to the transmission. I notice it when I go thru a drive tru. With the truck in Drive, there seems to be a rattle while the truck is stationary. As soon as I put the truck in neutral, the rattle goes away. I havn't really tried in Reverse as the people in line behind get nervous.
Do I need to go see the dealer or is this normal? 33,000 miles now. |
is it a rattle inside the cab, explain a little bit more about it. if its what i had when i put my shifter into drive 2 or 1 it would make a horrible rattle sound in the cab, i checked under the hood and the transmission dip stick was rattling against the ac tube thing. i just added another plastic tie around it and tightened it up and it fixed it. hope this helps
eric |
No the rattle appears to be coming from the transmission. It is especially obvious when parked next to a wall that reflects the sound.
There was a TSB out on that a while back. They replace the clutch disk with one that has different dampener springs. It won't hurt anything but some find it annoying. I left mine like it is.
Casey |
