Transmission question?
Old Dec 23, 2005 | 09:15 PM
0425004x4's Avatar
Question Transmission question?
My truck is relatively new with only 8500 miles but when shifting in to overdrive sometimes the RPM's will drop a little then go up and drop back down to where they should be (feels like the TC or tranny is slipping). This is not under heavy throttle or anything, just moderate normal driving. It has been doing this since I got it with 7,000 miles. Is the transmission slipping or what? This is not just a towing thing either, it happens empty sometimes but more often with a load. Could someone please help me out, if it is a problem how could I fix it? Thanks in advance guys.
Old Dec 24, 2005 | 08:14 AM
underwoodtransp's Avatar
I know a few guys here will slam on me for saying this but.... I believe you need a band adjustment. My truck did the same thing untill the dealer adjusted it and not it doesn't do it anymore...
Old Dec 24, 2005 | 04:56 PM
bluepp's Avatar
Dont let them tell you NOT to adjust the bands on a new truck . Its like everything else on a new rig. If done right at the factory ,you may never need the adjustment , but I'd do at least the first one at 30-35k even if working well.
Old Dec 24, 2005 | 07:44 PM
0425004x4's Avatar
Thanks guys. What is a band adjustment and is this covered under warranty?
Old Dec 25, 2005 | 02:44 PM
AKram's Avatar
I thought I had a band problem with mine. It was searching for gears mostly between 1st and 2nd. It turns out the pressure regulator and governor needed replacement covered by warranty. If I read my book correctly band adjustment is part of the required transmission service I think the interval is 30K for that not covered under warranty.
Old Dec 25, 2005 | 07:45 PM
Hounddog's Avatar
Sounds like normal torque convertor lock up.
Old Dec 26, 2005 | 12:11 AM
rockittboy's Avatar
can a fairly competent DIY mechanic adjust the bands? i am thinking i might need that
Old Dec 26, 2005 | 09:20 AM
jtb51b's Avatar
A fairly competent mechanic can do band adjustments just fine. Just grab the trusty service manual and get to it. On my 97 it required a "LOW" inch pound torque wrench. I would make for certain the wrench was accurate as well seeing as the bands are set at a very specific (and low) torque setting. It is not a hard thing to do, IIRC on my 47RE one band adjusted from inside, while another was adjusted from the outside.
Jason
Old Dec 26, 2005 | 10:20 AM
The one you are having problems with is the outside one. You can adjust it yourself but be careful because if you get it too tight you will take it out. If you search in these forums you will find a topic started about 2 months ago about this and I remember it having the exact torque spec.
Old Dec 26, 2005 | 03:36 PM
rockittboy's Avatar
thanks alot, i'll search right now
Dauntless
15
Aug 30, 2016 08:37 PM
turbospl311
Feb 4, 2003 09:14 AM
CRobey4393
Jan 16, 2003 07:54 AM
CNYRAM
Dec 23, 2002 11:32 AM
