transmission question??
Old Dec 20, 2006 | 05:26 PM
sootnpretty's Avatar
Hello, to start off my Dodge is the first chrysler let alone the first diesel i have ever owned, i havd the 48RE and when im driving around town when my trans goes to shift into overdrive it feels like it waits a little bit before it does actually shift, if that makes sense. i have driven some dodge trucks with the ctd like mine at work and they all shift like mine, but i havent driven it long enough or fast enough to get it to go into overdrive so i dont really have a basis for comparison. so basically im wondering of my truck is supposed to do that or is it supposed to shift right into OD? its not like a jerk of slip when it does go into OD, but its the time that it takes to shift, also the speed it like around 45-55 mph.
could this be the trucks way of telling me i need a band adjustment??
thanks adam
p.s. how many gears are in the 48re 4 or 5?
Old Dec 20, 2006 | 07:05 PM
bluebull's Avatar
Sounds like it's shifting normal under light to moderate throttle. Shifts will be firmer and at higher RPM's at WOT. Wide-Open-Throttle.
1,2,3,4, OD-lockup.
Old Dec 20, 2006 | 07:40 PM
duddin10's Avatar
Mine does the same thing. I agree with bluebull
Old Dec 21, 2006 | 01:49 AM
jestes's Avatar
Mine does that... I've noticed that around town, it doesn't want to shift untill about 42 mph. If you'll back off the throttle when you are ready to get it to shift, it should. After it's shifted, roll back into the throttle and you'll be set.
Dauntless
15
Aug 30, 2016 08:37 PM
turbospl311
Feb 4, 2003 09:14 AM
CRobey4393
Jan 16, 2003 07:54 AM
CNYRAM
Dec 23, 2002 11:32 AM
