Transmission Lines OEM only?
Old Mar 16, 2020 | 09:27 PM
anpconnors's Avatar
Michigan winters finally got to the transmission lines. Shop prefers OEM. Anyone use the Dorman option? or fab lines? Thanks!
Old Apr 12, 2020 | 08:49 PM
patdaly's Avatar
Sadly I am going through that right now, I am using Dorman, they look to be quality lines, only time will tell. I am assuming you have yours back up by now, did the shop tell you how much of a pain they are? I can't get mine to break loose no matter what I try, unless I get this thing up on a lift, I may be sending it into a shop myself.
Old Apr 12, 2020 | 08:57 PM
Fordzilla's Avatar
I've seen them so tight, I had to cut the tube off at the flare nut, and use an impact wrench judiciously to break it loose......Ben
Old Apr 26, 2020 | 11:52 AM
railroaderone's Avatar
You may have already fixed your problem but if not #6 steel braid hose is easier to work with and will last longer.
Ram_diesel2003
May 10, 2016 06:30 AM
b4black
Aug 1, 2012 10:03 AM
user name
Jun 14, 2012 09:04 PM
kennyblatz
Apr 29, 2008 12:16 AM
