Transfer case lubrication with hubs
Old Nov 12, 2009 | 07:00 PM
Highway 4x4's Avatar
I am about to go see Dynatrac but before I do I was wondering, if the front DS is not turning will the TC get lubed properly going down the road. There must be a pump in it, what drives it?
Old Nov 12, 2009 | 07:48 PM
92'1stGen's Avatar
When you say TC I personally can only assume two things, the torque converter, which I highly doubt you mean that, or the transfer case, which is what I think you mean. If so then the case than yes, it will still get lubed properly as the transmission is still putting power through the transfer case to turn the rear drive shaft in 2WD High.
Old Nov 12, 2009 | 10:52 PM
Yes I did mean the transfer case. I thought it would, now I am good to go.
wyododge
Aug 18, 2011 07:48 AM
91oldranchtruck
Jan 31, 2011 09:45 AM
fruitcakesa
Dec 9, 2006 07:44 PM
dkinzer
Oct 8, 2003 12:25 AM
