Transfer case issues
So i was at work yesterday and i was going to leave with a trailer on(about 12k) and it was kinda muddy out as well. All was fine until i started spining a bit. When i went to take my truck out of 4WD it would not. So i had to unlock the hubs to drive it. So i looked at of the fuses and the connectors on the shifter and then i took the shift encoder off. I had a buddy switch it from 2WD to 4WD and it moved fine. Then i left it for a minute and it started doing the same 2WD-4WD-2WD-4WD and it stopped in 4WD. So i still cant get my truck out of 4WD(yes i did it manually, i ment electronically.). Does anyone think it could be the shift encoder, Has anyone ever had this problem? Let me know soon as i need to get this figured out.
I gotta lever. Haven't heard of it. Try searching the forum if you haven't. Might have to let the post set for a while and let more people see it. Bump it a couple times once a day to see if you catch anything. I know in my old Silverado, the button assembly had to be replaced with similar problems. Actually pretty cheap. Less than $50?
dodger, pm me last 9 digits of your VIN. When I get home tonight (it will be late and can't do it on this work computer) I will search on dealerconnect and emial you the flowchart to diagnose it. also need your email so i can get you the pdf file.
Didnt get time to chris. I got a used one today that im gonna try tommorow to see. Couldnt turn it down at only 150 bucks to try. Hopin it helps solve the problem.
DodgeRamdiese01
May 2, 2010 07:44 PM
BAJA MAN
Jun 16, 2005 10:17 PM
