Trans temp 250*
Old Jun 11, 2008 | 09:35 PM
no_6_oh_no's Avatar
Originally Posted by SOhappy
So.. let me ask you guys with the sensor in the hot line this:
How do you really know when to pull over and let it cool down?
Of course you are seeing real time data, but it appears that's not always a good thing.
Never HAVE to pull over and let it cool down as we have real time data. When the output temp starts getting up there its time to lock the TC and no more issues. If it doesn't cool down there is a problem to be addressed.
If you read temp after it has been cooled how can you even begin to see where you need to adjust driving tactics? What temp "trend" will tell you your fluid is cooked when there can be upwards of 100 degrees difference between hot line and pan? You will not see, feel, or smell when ATF+4 has lost its usefulness. Only a chemical analysis is going to tell you that. Seeing how many times the temp spikes is about the only gauge that is available to for judgin when it is time to change the fluid. Its the least inaccurate of all available.
Quite frankly, ATF+4 is way underrated for its ability to withstand abuse. From what I have seen, 99% of us don't ever need a 30k change as we never approach the limits of the fluid. Somebody has to support Amsoil, Chevron. Valvoline and the rest of the oil manufacturers, though.
Old Jun 12, 2008 | 01:33 AM
blwnsmke's Avatar
Originally Posted by RonP
I have the gauge in the hotline and it acts exactly as stated above. I have seen 250 a couple times running around town in 90+ degree weather. If it is already at 190 or so and I run from one light to another, the tighter converter builds a good bit of heat and since it never locks up between lights, it eventaully gets to the 250 mark. I don't worry about it. If I pull it down to 2nd and let the converter lock, it starts cooling instantly. nature of the beast.
I have a manual lock up switch.. But what exactly do ya mean by pulling it down to 2nd? When leaving a stop light?
Old Jun 12, 2008 | 07:42 AM
no_6_oh_no's Avatar
The TC will lockup in manal 2nd, and, you can get it to lock earlier with a switch.
Old Jun 12, 2008 | 10:52 AM
RonP's Avatar
Correct, I don't even do that much, I was just saying that once it locks you can see how fast it will actually bring the temps back down.
Old Jun 12, 2008 | 11:03 AM
paroxysym's Avatar
my gauges jump around like that from time to time and its usually my tranny one that does it. its the ground for the gauge, id check there. usually mine buries itself at 250, it will do this while the converter is locked cruising along. its the ground fr the gauge cause it comes back to normal temp and stays there for the duration of my drive.
Greed 93
Jan 31, 2010 09:26 PM
mar67655
Mar 21, 2009 05:35 AM
smoky beast
Feb 26, 2007 09:17 AM
philobeddo
Jun 15, 2006 06:16 PM
guh2stroke
Dec 24, 2005 08:45 PM
