trans slips after truck sits
Highly unlikely damage would occur with that scenario. Nothing is really dry, and, the fluid will flow from the sump to the pump then to TC. You will have line pressure to apply the clutches before the TC fills becuase the pump is the source of the fluid fill and pressure for the clutches. The reason it is slow moving is due to the lack of fluid in the TC for the fluid coupling to function, not a lack of clutch apply pressure.
To reiterate really well hashed over issues, the main reason to mod the VB for fluid flow in park is due to the fact that in park the pump HAS NO LUBE. The manual valve blocks fluid coming from the sump and there is less than a pint of fluid in the pump gears on start up. Idling the engine for any length of time is hard on both engine and trans unless mods are made. Shifting immediately to neutral on startup is is about the only to mitigate possible damage.
Highly unlikely damage would occur with that scenario. Nothing is really dry, and, the fluid will flow from the sump to the pump then to TC. You will have line pressure to apply the clutches before the TC fills because the pump is the source of the fluid fill and pressure for the clutches. The reason it is slow moving is due to the lack of fluid in the TC for the fluid coupling to function, not a lack of clutch apply pressure.
Fixing the park pump problem actually is a band aid to the leak down that occurs, but is not noticed with the lube in park fix. Trying to find and repair the leak down on any given transmission can be hair pulling and I might add, pulling the trans a few times. If you want to get technical about it, the problem comes from an excess gravity leak down of the converter through the transmission and has nothing to do with the "no pump park" problem although the leak down is covered up by the park fix.
Any time you try to pull away from a stop and there is not enough fill in the converter or pressure to engage it, you are damaging the trans front clutches or the clutches that are engaged in reverse.
This makes sense as damage would occur if the clutches are slipped like you imply. That just doesn't happen on a good trans.
If you are burning up the forward clutch pack there are other internal issues causing it.
Jmac
Nov 6, 2013 07:49 PM
ruthilltn
Sep 7, 2010 07:01 AM
Strjock81
24
Dec 10, 2004 01:32 PM
