Trans drain plug suggestions
Last summer, I replaced the govenor pressure solenoid and installed the B&M drain plug.
Well, the little plastic washers were crappy, because now it's leaking and I need to replace it with a better option.
Do any of you have any suggestions for a better drain plug? I'm thinking of installing the Fumoto one for the trans and oil pan.
Thanks!
Thanks!
You can replace the plastic washer with a better copper one. Or since you already have the B&M you can just weld the inner bung and not deal with the washers! The Fumoto is another good option but not sure about the hole size differences...
Chrisreyn
Jan 4, 2007 09:42 AM
gnuesse
Jan 2, 2006 09:46 PM
