Tranny Issue(Codes)
Old Aug 3, 2007 | 08:58 PM
Nate-03 D's Avatar
Tranny Issue(Codes)
Anyone here know what this code is? P 0700? I'm pretty sure it is tranny related but I don't know the exact specifics of it. Would this code cause a truck to defuel at 2500 rpms or so? I think I played a little to hard and now the ball has landed in my court(time for some good ol wallet denting)
One more question. I know by cycling the key on/off 3x shows your codes. Those kinds of codes are stored in the PCM? They cann't be erased by say a basic DTC scanner can they? I went to Advanced Auto to see if it would clear and it still stayed in my system. I tried using the Bully Dog but it just sayed no DTC's. I think that only works for actually CEL's(which I have none popping up).
Old Aug 6, 2007 | 01:19 PM
RHC's Avatar
RHC
This is what i found on the code..P0700 Transmission Control System (MIL Request)
Not sure what it means.
Old Aug 6, 2007 | 01:29 PM
vzdude's Avatar
DTR's 'Go to Guy'
O.K. here is why. You have 2 control modules on your truck. An ECM for the engine ( Cummins ) and then a PCM (powertrain control module- DODGE )for everything else like cruise, transmission , alternator, all the other stuff. The ECM doesn't control the transmission, yet it needs to know if there is a problem in the PCM so the PCM will send a code p0700 to the ECM. The odo trick doesn't read the PCM codes so you can't actually tell what is wrong without a scanner. Most scanners have 2 selections when you hook them up. It will ask engine cummins, or engine pcm. Maybe the cheaper scanners like Autozone and such don't have the capability, I don't know for sure. Anyhow, there is a TSB for an erroneous P0700 code if there aren't any transmission codes in the PCM. You have to reflash the ECM. Hope that makes it clear?
exwrestler
Feb 5, 2010 09:34 AM
sallyman1
Aug 26, 2008 06:20 PM
mbenedict
Jul 21, 2007 09:19 PM
DDysput
May 5, 2004 07:44 AM
