torque verter lockup switch not working right
Old Dec 27, 2006 | 01:54 PM
ZacHolley's Avatar
I put the lockup switch on my truck last night following this howto
https://www.dieseltruckresource.com/...ferrerid=27932
it wont lock in until like 40 and it locks overdrive and it only does it part of the time.
on the round plug on the tranny there was a green and a blue wire, we tapped into the blue one.
any idea's on what is wrong???
Old Dec 27, 2006 | 07:18 PM
ZacHolley's Avatar
TTT wish somone that had one could help??
Old Dec 28, 2006 | 01:11 AM
no_6_oh_no's Avatar
Which method did you use? Did you check the FSM to make sure that blue wire is the CORRECT wire?
According to FSM it shouldbe the black/orange wire.
Old Dec 28, 2006 | 10:03 AM
chucktuna's Avatar
I posted this in another location too, but same issue, so same question.
ZacHolley, which resistor did you use?
Radio shack shows two different 33 ohm resistors on line with different part#'s
I assume I need the 33 ohm NOT the 33K ohm, right?
(271-1104 is the correct one?)
And, any more long term effects from some of you guys that have had this mod a while?
$0.99
33 ohm 1/2W 5% Carbon Film Resistor pk/5
Model: 271-1104 | Catalog #: 271-1104
Reduce the flow of electricity in your project with this 5-pack of 33 ohm carbon-film resistors. 1/2...
or
$0.99
33K ohm 1/2W 5% Carbon Film Resistor pk/5
Model: 271-1129 | Catalog #: 271-1129
Reduce the flow of electricity in your project with this 5-pack of 33K ohm carbon-film resistors. 1/...
Any guidence would be most appreciated!
chuck
Old Dec 28, 2006 | 12:23 PM
no_6_oh_no's Avatar
Either one should work. The ECU wants to see between 5 ohms and 100k ohms resistance to not throw codes.
Old Dec 28, 2006 | 03:30 PM
BigDave12768's Avatar
Could the Juice with ATT be causing an issue? Don't they control the Lock up or monitor it?
Old Dec 28, 2006 | 04:25 PM
chucktuna's Avatar
I believe this is the connector in question...funny, it doesnt look like this in real life
but anyway. just making sure this is correct cause the diagram shows the #7 wire to be YL/LB.................yellow/light blue...right?
as highlighted in the red circle:
Hope this scan is visible.
chuck
Old Dec 28, 2006 | 04:47 PM
no_6_oh_no's Avatar
It should or you have the wrong connector.
Thats the correct wire to tap.
Old Dec 28, 2006 | 05:22 PM
ZacHolley's Avatar
hmmmm well my friend was the one splicin into the wire on the bottom and he said on that round plug toward the back of the tranny was only a blue and a green and he said it was the blue one...
and whats a fsm??
Old Dec 28, 2006 | 07:54 PM
no_6_oh_no's Avatar
and whats a fsm??
The plug at the back of the tranny is probably the output speed sensor. You need the 10 wire plug that is about the middle of the trans on the drivers side. It should be vertical and pointing up towards the floor boards of the cab.
Old Dec 28, 2006 | 08:11 PM
ZacHolley's Avatar
that plug is a rectangle though??? i thought they said do the round plug???
Old Dec 28, 2006 | 11:45 PM
no_6_oh_no's Avatar
Yeah, with the connector it is rectangular but the plug itself is a round configuration. See the picture above as that is the correct plug and wire color to tap.
Old Dec 29, 2006 | 12:33 PM
ZacHolley's Avatar
well dang how is it working in overdrive if i'm just grounding out my speedo sensor lol???
Old Dec 29, 2006 | 02:09 PM
no_6_oh_no's Avatar
I don't even want to guess. Sounds like you are getting the normal lockup operation.
According to FSM it should be the black/orange wire on the connector to the middle of the trans. Try that and see what happens.
Old Dec 29, 2006 | 04:27 PM
ZacHolley's Avatar
no it is locking up once its in drive or overdrive it will lock about 40 then stay locked to like 20 where it starts shuttering hard.
man it will smoke like a SOB about 35mph with juice on level 5 haha
