Torque convertor upgrades?
Old Nov 11, 2006 | 10:21 AM
DieselLady's Avatar
ATS all the way. 3 yr 150k mile warrenty in writing. Firm shifts but not to violent. The problem with a lot of single disc converters and the VB kits is they bump up line pressure in order to hold the clutch in the converter. Necessary because the disc is usually wider than stock so more surface area = less pounds per sq inch. Stack the clutches ( 3 or more discs) and you have lots more surface area with the same psi across them.
I have driven lots of trucks with lots of different trans mods. Can't recommend ATS highly enough. And BTW. You can talk to the owner.
You will spend a lot on a converter and vb and the $$ to R and R the trans. I would buy the best, not that much more money and you won't be doing it again.
93dieselZak
Jun 16, 2011 06:10 PM
J BODY
Feb 10, 2004 11:50 PM
turbospl311
46
Jan 18, 2003 06:36 AM
RickCJ
Dec 15, 2002 06:04 PM
