torque converter
Old Jun 9, 2005 | 09:15 AM
Bleu Goat's Avatar
Question torque converter
In the 2003 48RE is the torque converter supposed to lock up in third gear when the OD off button is engaged? Mine seems not to. When towing at lower speeds (below 60 in the hills) and locking out OD to keep rpms up the trans temp goes up.
Old Jun 9, 2005 | 03:29 PM
SBishop's Avatar
My '03 with a 47RE locks up in 3rd. After dropping out of OD try easing up on the go pedal a little bit and see if it won't lock up for you. In 3rd, the lock up is very subtle and you have to watch the RPM guage to catch it. Only about a 100 RPM difference sometimes.
Old Jun 9, 2005 | 03:57 PM
Hal's Avatar
Hal
Mine locks up in 2nd at around 30 (I think), 3rd at exactly 50 and OD at 55 depending on engine load. Seems to be consistent towing or unloaded.
Old Jun 10, 2005 | 07:13 AM
Bleu Goat's Avatar
Thanks for your replies. Going to the dealer next week for differential fluid change. Will have them check out the torque converter then.
lniemeyer2
Oct 24, 2012 12:11 PM
93dieselZak
Jun 16, 2011 06:10 PM
mainer
Jul 17, 2007 07:13 PM
