Top end rattle
Top end rattle
I'll try to keep this as short as possible. I have a rattle in #1 that sounds like an injector failure. But all injectors have been replace with tubes and 1-3 have been replaced again because we thought we got a bad (new) injector with tubes. Have retimed cp3,replaced 1 fuel line,fluxed head and installed seats and rockers,replaced check valve in head,replaced pressure relief valve in rail, disassembled rail and cleaned, check rods and mains, no scored cylinders. #1 fuel line pulsates really bad but 2-6 feel fine. If anybody has any info on what this might be it would be much appreciated, I'm running out of hair. Thanks.
Dealer is doing the work,thought they would have. Still on warranty but I don't have a lot of faith in the dealer. Rattle comes and goes, it's not consistent like a wrist pin or bad bearing. I've taken it to a couple diesel shops and a cummins dealer and they say I have a problem.Thanks for the info. I'll check with the dealer to see if they did. Any other ideas?
