Tires vs. Mileage
Old Jan 19, 2007 | 01:30 PM
FishingFather's Avatar
Tires vs. Mileage
I keep hearing that bigger tires will result in worse fuel milage. I am thinking of going just a little larger than the stock tires and wheels. At what point do you guys start seeing your mileage change? I am currently getting 18+ stock and really don't want to loose much. Any examples are greatly appreciated.
Old Jan 19, 2007 | 01:35 PM
RamWheelsBy4's Avatar
When I put the BFG 315s on I lost about 1-1.5mpg city driving. My highway mileage stayed right about the same.
Old Jan 19, 2007 | 01:54 PM
Raspy's Avatar
My 315s cost me about 1-1.5 MPG in combined highway/city. Probably about 60-70% highway. Then I went to 285s and got about half of that difference back. Plus the truck drives better with 285s.
Wetspirit
Old Jan 19, 2007 | 02:54 PM
Texasimport's Avatar
Yep same here traded in the tiny stockers and filled the wheel wells with a set of BFG 315's I went from 20 and change down to low 19s.
Old Jan 19, 2007 | 05:22 PM
elkman12's Avatar
Changed from 245 to 265 and had a little more aggressive tread. Dropped 1.7 city 1.5. HWY. Had running numbers for 12Years.
Old Jan 20, 2007 | 07:40 AM
Mark Hodowanec's Avatar
First off, I need to state that I have a 6 speed, and you have an auto. The auto guys seem to lose a little and the 6 speed guys seem to gain. With that said, I gained about 2 mpg switching from stock 265s to 315s. I currently get 21 mpg w/ my 35s on. This is not a 'best tank' number, but a true MPG as I keep track of all the fuel that goes into my truck. See my prior post "MPG Graph for last 53,000 Miles!" for the graph - the graph shows when the 315s went on.
https://www.dieseltruckresource.com/d...d.php?t=129749
Old Jan 20, 2007 | 08:44 AM
Geico266's Avatar
Remember guys, when you put bigger tires on you throw your speedos off.
Old Jan 20, 2007 | 10:21 AM
Silver76's Avatar
My results are the same as Mark's. With the g56 and 315 BFGs on stock rims, I gained a little on mileage. (I used the flashpaq to correct for larger tires.) The majority of posters running autos lose mileage with the bigger tires.
Old Jan 20, 2007 | 01:48 PM
rockcrawler304's Avatar
True.
Is everybody correcting the math for thier results?
Old Jan 20, 2007 | 02:20 PM
RickCJ's Avatar
It's not so much the height of the tire but the width.
A tall skinny tire will do better than a short wide tire. as long as you keep the engine in it's sweet rpm range.
Also an agressive tread tire will do worse than a smooth street tire.
So a tall skinny tire with smooth tread design and somewhere close to 2000 rpm will do best!
Michelin LTX are very good at this!
Old Jan 20, 2007 | 03:09 PM
True.
I can't speak for everybody, but my speedo is corrected.
Old Jan 20, 2007 | 03:12 PM
I agree, but the only other option to run a 35" tire is to go to a 265/70-19.5. Then you would also have the benefit of being able to run at higher pressure. I would love to do that, but don't see spending $2K to $3K to put on some Rickson's.
Old Jan 20, 2007 | 03:38 PM
nitis's Avatar
Good point mark also I do not want to replace my fillings those 19.5s cant ride that good
Old Jan 20, 2007 | 04:48 PM
jmccart's Avatar
With my G56, in 6th, w/3.73's it is almost like a NVG5600 and 4.10's. 2.91:1(G56/3.73's) vs a 2.99:1 for the 5600/4.10's. I want to go to a taller tire big-time.
chrisminx
14
Jul 7, 2010 06:48 PM
1320
May 29, 2009 10:24 PM
sakisaki400
23
Dec 31, 2006 10:17 PM
Captain
Sep 9, 2005 12:16 AM
