Tire Size
Old Dec 26, 2007 | 06:44 PM
workingdog's Avatar
Setting Tire Size with tuner
bump
What are people using to set the tire size in their PCMs? I'm runing 33's and everything is off about 15%. I know the and mileage will be wrong, but does it cause any other trouble to run with the wrong tire size? Dose the transmission care? This is a 2005 HPCR 5.9l with 48RE.
Peter
Old Dec 27, 2007 | 08:07 PM
carri56's Avatar
you can go to the dealer and get recalabrated for the new tire size.
Old Dec 27, 2007 | 08:09 PM
Rednecktastic's Avatar
Most programmers will do the trick...
Old Dec 27, 2007 | 09:20 PM
JP-4.5's Avatar
If you know any mechanics with the Sun or Snap on scan tools they can also set for tire size in the ABS section. A local diesel shop set mine with their Snap on scan tool when I added the 19.5 tires to my truck. I try and stay away from the Dodge dealers when ever possible.
Jeff
Old Dec 27, 2007 | 09:23 PM
You're the guy with the cummins swap right on another thread?
I'd stay away from dodge as said by JP and go find someone with a scan tool that can fix you up. I think dodge requires $85 (what i was quoted) and they can't even get it right since they are limited on options I've heard.
oldwhite12v
Mar 25, 2011 04:28 PM
schoust
Oct 21, 2009 10:09 AM
bigdogtruck
18
Nov 21, 2007 08:09 PM
4RnrRick
Feb 27, 2007 11:25 AM
ValkSmile
Jan 23, 2007 11:42 AM
