Timing rattle
Timing rattle
Well i just got my truck back after 2 weeks of being at the dealer. I had them replace all 6 injectors,injector harness,fca,fuel filter,ecm,winn module,2 new keys,fuel pressure sensor. So after all this i pick the truck up and noticed it was considerably louder than before, it sounds like when you add to much timing it gets that hard rattle, sounds just like when i run my quad adrenaline on 8 or 9. Is this normal with new injectors? Is there a way the tech could have added more timing when he reflashed the ecm. Any ideas would be great before i take this thing back. Also it is getting a hell of alot better fuel mileage.
New injectors can sound crisp and quiet down in a few thousand miles. The ones on our CATs did just that.
ECM reflash could alter the timing map for sure a possibility.
Too much timing + load will melt down pistons on any diesel and not show high EGT either. The two are not related. (The rare few diesels with steel crown pistons will not melt) Ours are aluminum and will melt.
There are ways of measuring the timing to confirm what is actual. I do not believe there is any way to get the timing on the CRD out of time mechanically. The sensors and wheels cannot be indexed as far as I know. Any timing changes are all electronic.
acook
Apr 1, 2007 10:10 PM
templer
Jan 24, 2007 12:16 PM
Buffalo
24
Jan 3, 2006 05:28 PM
foley
Jun 1, 2005 03:54 PM
