ticking-i searched
Old Feb 22, 2008 | 04:20 PM
Tyler's Avatar
ticking-i searched
everythig i searched that involved ticking seemed to be constant, or alteast have a pattern. lately, ive been expirencing a very erratic ticking. i cant make it tick. it tick for no reason. it might tick like crazy for 10min, then not do it for another hour. i would trace it, but i cant make it tick at idle. it does it with the heater on/off, ac on/off, or everything turned off. it does seems to tick more while im slowing down instead of speeding up or ruising. its very faint and i can only hear it with the radio off. i did have a code come up saing tha the a/c cluth is low, wat does that mean?
specs: 2003 CC SB 2wd, 305/555, 6 spd, 130k, BDPP, AFE filter, everything else is bone stock.
Old Feb 22, 2008 | 04:40 PM
trik396's Avatar
The ticking you are hearing is most likely your injectors. Try running some diesel injector cleaner added to your fuel and see if that helps.
Old Feb 23, 2008 | 07:55 PM
Tyler's Avatar
ok thanks. what do yall suggest?
Old Feb 23, 2008 | 08:50 PM
Totallyrad's Avatar
There is also a ticking issue that involves a missing or broken injector line clamp. I just can't remember what year model it was on.
On edit, I did a little quick searching and found there was an issue reported on some 03-04.5 trucks involving the #6 injector line. I used the following keywords in the search. Remember to select posts, not threads. Hope it helps.
missing fuel line bracket
1985cucv
Apr 11, 2010 10:42 AM
berok
Apr 27, 2006 10:01 PM
Maccandy
May 16, 2004 09:25 AM
JaimeZX
May 12, 2004 11:36 PM
Big Rich
Jan 13, 2004 06:57 PM
