front drive shaft grease
Old Feb 23, 2008 | 03:50 PM
SDHNTR's Avatar
Is there any aftermarket grease that meets the MS 6560 specs we are supposed to use in the front drive shaft? I know I can buy a tub at the dealer but a tube to load into my grease gun sure would be easier. I can't find anything at the local parts store that meets MS 6560 as indicated on the tube. Little help?
Old Feb 23, 2008 | 06:47 PM
salesrep's Avatar
There are many good greases to choose from that should be easily attainable for this application. Don't go cheap.
Where/shat is ms 6560 spec?
Old Feb 23, 2008 | 09:02 PM
SDHNTR's Avatar
Care to elaborate or be more specific? The owners manual clearly says MS6560. No grease I can find meets this spec. You name the Chey, Ford and other Chrysler ratings and you can find it, not the case for MS6560. What kind of grease are people using?
Old Feb 23, 2008 | 09:58 PM
salesrep's Avatar
The ms6560 is just the part number for chrysler. A general pupose lithium based nlgi#2 grease. This grease is nothing special. Any napa or autozone will have several fine choices to choose form. Perhaps some of the others can chime in on what they are using.
Old Feb 23, 2008 | 10:32 PM
hugger37's Avatar
i use aeroshell 5. same old lithium based grease that looks just like the lithium grease from napa but we use it to grease airplane propellers.
quicksilvr
37
Dec 22, 2009 05:22 PM
bansh-eman
23
Feb 24, 2008 07:36 AM
yank88
Feb 20, 2008 01:04 PM
24seven
17
Jul 11, 2007 12:23 PM
lakotacatwalker
Apr 10, 2005 04:35 PM
