Throttle Sticking
Old Dec 22, 2023 | 04:53 PM
JARHEAD's Avatar
Throttle Sticking
Hi, on my 2006 2500 4x4, auto, 150k miles, I have found in other posts that throttle sticking while driving can be the converter, etc. I just cranked my truck up for first time in a month and gave it some throttle while in park and it came down slowly, sat at a high for a couple seconds and then came down gradually and in steps. No idea if it will do it while driving, I cannot drive. I just had surgery and in no shape to go on the hunt for a cure without some help up front. Thanks for any help.
Old Dec 23, 2023 | 06:37 PM
nonrev's Avatar
Super Moderator
10 Year Member
My 04 does it all the time not a fun thing on slick roads.
Old Dec 24, 2023 | 01:43 PM
nothingbutdarts's Avatar
Did it start right up after sitting a month or did it seem like it might have gotten some air in the fuel?
Old Jan 9, 2024 | 12:02 AM
LeonardHane's Avatar
Any update?
Spoiler
Old Jan 9, 2024 | 09:59 PM
JARHEAD's Avatar
I am hoping to hook trailer to it this weekend to get it good and loaded for a while and also check on a few things I was told to check. Been too sick to do anything yet.
Old Jan 20, 2024 | 09:49 PM
Jeff in TD's Avatar
It would be interesting to manipulate the accelerator while watching throttle position reading on a scanner.
I’d also read somewhere that excessive fuel injector return flow can cause the engine to kind of hang when coming off the accelerator. Apparently under load the ECM has to keep stepping up the EC3’s output more than normal to achieve the desired rail pressure, but then when you come off the throttle rail pressure ends up higher than commanded until the ECM and pump react.
Onemoparnut
Aug 19, 2013 08:11 PM
bradshaw106
May 20, 2008 04:58 PM
halerazor
Sep 26, 2006 08:39 PM
