temp gauge on 6 speed
Old Mar 21, 2010 | 09:25 PM
Farmall Power's Avatar
I have a empty spot for a gauge and im goign to put in a temp gauge for the trany, the 6 speed dont really need it but cant think of a better gague to put in, where can i get a temp sender to put in the trany and where to install it?
Old Mar 21, 2010 | 09:51 PM
Hudge's Avatar
im not tryin to step on your toes man but y dont ya just buy the correct amount guage holder and sell the one on ya got instead of buying a possibly unessesary guage......thats just my $.02
Old Mar 21, 2010 | 10:11 PM
CD in NM's Avatar
I installed a temp gauge in my 6-speed tranny, I drilled one of the side covers and welded on a threaded bung for the sender. I did that when Iwas changing the tranny fluid. After a year of monitoring my tranny temps, I then installed a pair of fast coolers, they have a port for the sensor.
If you tow a lot, and if you tow heavy, the tranny temps WILL suprise you, they certainly suprised me, I am glad I installed the tranny gauge. I now know why the recommended fluid changing levels are at 15K, the tranny fluid DOES take some heat abuse.
I don't mean to be rude Hudge, but once you actually get to see what tranny temps ARE the gauge is NOT un-necessary - I speak from experience.
I installed a 4-gauge overhead pod for temp gauges - oil temp,tranny temp, f & r diff temp. The considered 'more mainstream' gauges I have in a dash pod - fuel press, rail press, boost, and EGT.
Since I have an exhaust brake, I decided to monitor it as well, I have a brake press gauge in the single SRT-10 a-pillar pod.
Usually the temp sensor/sender comes with the gauge packaging.
CD
Old Mar 22, 2010 | 12:16 AM
nwflyoda's Avatar
Originally Posted by CD in NM
I installed a temp gauge in my 6-speed tranny, I drilled one of the side covers and welded on a threaded bung for the sender. I did that when I was changing the tranny fluid.
thats exactly what i did. i just don't have the gauge yet. i plan to also run a rear end and tranny gauge due to towing. i'm glad to see that it does come in handy like i expected.
Old Mar 22, 2010 | 04:25 AM
6 Shaker's Avatar
I too added a gauge to my G56, exactly in this way. I also added a rear diff. temp gauge. Man is it ever an eye opener while towing how hot these oils actually get.
Old Mar 22, 2010 | 11:19 PM
Brad5502's Avatar
Real interesting to watch the tranny and rear diff temps when towing a heavy 5th wheel. My rear diff temp seems to run higher by 20-25 degrees. Maybe placement of the sensor or the trans cooler is actually making that much difference?
Just more info to help if you have to troubleshoot. Glad I got mine.
Old Mar 23, 2010 | 08:52 PM
D-Roc's Avatar
CD
What are some of the temps you see?
I've found my shift quality degrading awfully quickly and have been thinking it's a matter of changing fluid often.
Old Mar 23, 2010 | 09:00 PM
rockcrawler304's Avatar
CD
I thought the G56 was recommended at 50k miles I don't have my manual right here to look yet.
After reading this I think I will also put a gauge in my tranny.
I would also like to know what you guys are seeing for temps not towing vs towing.
Old Mar 23, 2010 | 10:13 PM
Brad5502's Avatar
5sp Man trans unloaded 140-150, rear dif 150-160
loaded trans 160-170, rear dif 190-200
Old Mar 24, 2010 | 06:05 AM
6 Shaker's Avatar
While towing my ~8000 lb trailer with flipped axles and 2 quads on the deck of the truck into a head wind I've seen 215* on both the tranny and rear diff. Usually though they are anywhere from about 170-190* depending on terrain and wind. Empty I can see 160 on the the tranny when its hot out. (80* or warmer). The diff is about the same.
I too have a noticed a shift quality difference when the oil is hot, but once it cools down a little bit it goes back to normal. I change the oil once a year for cheap insurance and it always looks as good coming out as it did when it went in.
mar67655
Mar 21, 2009 05:35 AM
Suneview_Farm
Dec 25, 2007 10:18 PM
goodeyesniper75
May 16, 2007 01:58 PM
DennisT
May 11, 2007 08:58 PM
Bad Ramer Jamer
Dec 1, 2005 02:30 PM
