TC Lockup Switch,
In addition, that boy can't decide if its a manual or auto.
You need to tap pin #7 on the trans control connector, run the wire to one end of a single throw switch, wire a 25ohm 1/2 watt resistor between the other end of the switch and ground.
Failure to do so will result in CEL events and put the trans into limp mode.
If you will note the description it doesn't work on 1999 and up vehicles.
Theres gotta be a way to do this on the 47/48re 99 and up trucks also. I hate where my converter locks up. If knowone knows how to do this I will get the service manual and figure it out. There is nothing more annoying than getting behind someone doing 40 which is right where the converter locks up and having it go in and out of lock-up. Also, dodge really screwed up the logic in the trans brain, it always locks up right when I don't want it to.
THANKS M/T ...HERE IT IS ...
The Definitive Howto: 04.5-05 Tc Lockup Switch
Since alot of people are asking, and I've tried without success in the past. I decided to work on it a little today and figured it out. My 05 can lock the TC up in FIRST GEAR. I thought you needed a modded VB for that, guess not. It's really simple to do this. All you need is a on-off switch. Ground one side to metal anywhere in the truck. I mounted my mystery switch next to my MP-8 volume ****, just to the right.
Go under the truck and disconnect the ROUND plug. Put a tap however you like into Pin #7 and run the wire to the switch. Now go to the fuse block and find #59 relay. It's next to the fuse marked 50. Put a peice of wire between Pin #'s 30 and 87, not 87A. Your done now. It will even lockup in first. I just did a burnout (no camera ) I started it in first, got some wheelspin, hit the switch, moved to 2nd, then D and smoked them like I never have about a block long. 4wd launches are alot more fun. Just remember to ground pin#7. It's great.
Finish reading that thread, you don't have to mess with the relay. Just wire a resistor into the switch to pin #7. This should work the same way on all the pevious years also. Just find the TC lockup sense wire for the particular year.
Yes. The system monitors resistance between 5 ohms and 100k ohms. Anything outside that range triggers limp mode and a CEL. Amy 1/2 watt or 1 watt resistor from 5-100k ohms will work.
one person says 'ground it(#7)
the other says DON'T dead ground it put a resister in line...
Angry Johnny
Aug 23, 2016 05:01 PM
93dieselZak
Jun 16, 2011 06:10 PM
