Taking inner wheels off dually???
Old Mar 27, 2008 | 08:36 AM
cscott67's Avatar
Question Taking inner wheels off dually???
I am using my 07 dually for mostly commuting, and snow is amost gone. Has anyone tried running only the outer wheels and taken the inners off to increase mpg? Just want to make sure it is safe and if it makes a gain in mpg. Thanks in advance for any advice, Scott
Old Mar 27, 2008 | 08:47 AM
Rollin' Smoke's Avatar
I have seen this done on another truck around town.....dont think it was done because mileage. the truck looked stupid IMO and i dont think it is really that safe. I would say if you that worried about mileage then you might as well just get a single wheel instead of a dually. that might gain you a little mileage but probably isnt worth all the hassle
Old Mar 27, 2008 | 10:02 AM
rich's Avatar
you can do it dont believe that the less 200 pounds will matter
Old Mar 27, 2008 | 10:15 AM
Jeff in TD's Avatar
I've seen people do it to get a bit better traction in the winter. Reminds me somehow of a dog that came back from the vet.
Mileage wise, I doubt it would improve that much. The dually I have now gets about 1.5 or 2 or so less on the freeway than the SRW I had, but I think part of that would be going from the 03 HO to the 600 and from the NV to the G...
Safety wise, as long as the lugs are tightened properly I don't think it would be an issue.
cscott67's Avatar
Question I agree about the looks.......
The loss of the weight is not the key, it is the loss of the rotational mass that makes the most difference. I haul a 32ft tag trailer 4-5 times a year and appreciate the dually for that. The rest of the time I use it for work and contracting with small trailers and loads. I just want to be sure it is safe first. (I can always slap them back on if there is no mpg gain) Thanks, Scott
Old Mar 27, 2008 | 10:19 AM
Jeff in TD's Avatar
I'd say, then, break out the floor jack and the torque wrench and try it.
If it handles funny, or doesn't improve MPG, it would only take a few minutes to put it back.
Since my last SRW and this dually weren't identical otherwise, I can't say I've made a direct comparison, but my semi-educated guess is that you might see 1 mpg or a fraction there of...
Let us know how it turns out.
Old Mar 27, 2008 | 01:36 PM
dodgeduner's Avatar
Dually's rule
Old Mar 27, 2008 | 01:59 PM
paroxysym's Avatar
why not just go to a super srw?
Old Mar 27, 2008 | 03:54 PM
TonyB's Avatar
AKA super single
I think Rickson offers something like that.
Tony
Old Mar 28, 2008 | 01:06 AM
Performance's Avatar
Any increase in mileage isn't going to make up for how funny it will look.
Old Mar 28, 2008 | 03:26 AM
n2moto's Avatar
Yes it is safe. Savings? Less wear and tear on $400 plus worth of tires and breaks. As mentioned above less rotating mass to start and stop. All things combined you should see some savings but I don't know if you'll notice it.
You can now have 3 tires and wheels to put into a rotation schedule and extend the time for tire purchase.
Old Mar 28, 2008 | 08:27 AM
BINGO.....what does he win?!
Old Mar 28, 2008 | 09:00 AM
CD in NM's Avatar
I used to bolt up a set of SRW type wheels/winter treads on my Ford dually in the winter. It DID look funny but was much better in the snow/staying in the tire ruts, etc.
If you have your dually rims and use the rim pointed out, it should look fine as far as the tire going to the outer edge of the wheel well. Not a safety issue, should tighten up just fine. I know weveral people who only run all their dually tires when hauling/towing heavy. It should decrease resistance.
CD
Old Mar 28, 2008 | 12:43 PM
cscott67's Avatar
Talking Thanks for the "safety ok" posters!
As for the rest of you fashion model/srw haters!! ;o) I gotta try something to get those mpgs up, S
Old Mar 28, 2008 | 07:20 PM
RAMRODD's Avatar
Actually if you have some nice dually mudflaps on your truck most wont even notice.
