stuck gauge
Old Aug 9, 2009 | 11:50 AM
Blackedout1ton's Avatar
stuck gauge
is it possible when put my fuel tank back together i got the float inside the tank stuck? i had the tank out to clean it out after i had bad fuel and after re assembly the gauge hasnt worked. any advice would help.
thanks guys
Old Aug 9, 2009 | 06:47 PM
BigIron70's Avatar
Cummins Guru
That's very possible the fuel lines should be 90 degrees to the center line of tank. The float is pointing forward so it might be hitting inside wall of tank not allowing it to drop. I have rotated the module a little if you loosen the locking ring first. Just be careful that the fuel lines are not put under and strain or kinked since they are plastic and will kink if bent to sharply. Good Luck
Old Aug 10, 2009 | 08:20 AM
thanx for the help, ill try that and see if it will free up
Old Aug 10, 2009 | 03:11 PM
well i messed with it today and it seems to be working, i will have to fill er up tonight to make sure, thanx for the help
birdboy
Dec 12, 2018 09:02 PM
birdboy
Apr 21, 2012 09:44 PM
Baja
Jan 29, 2008 08:17 PM
hemertwv
Dec 15, 2005 10:25 PM
04ctd
Sep 14, 2004 04:43 PM
