Stop and Go With Auto
Old Aug 30, 2007 | 07:13 PM
wadediesel's Avatar
I have a job that requires me to stop and go. I will possibly drive 100ft and then stop, exit the truck then get right back in and go another 100ft.I repeat this around 300-400 times in around 5-6hrs.
My Question is - would it be better for me to leave it in drive and use my
E-Brake rather than going from Park to Drive every time. Is there a possibility this could over heat the Tranny? I do not pull-haul anything during this time.
There is times however where I will drive a 1/2mile at 30-40 MPH until my next stop (not very often).
Thanks for your info and advice.
Old Aug 30, 2007 | 07:42 PM
Spooler's Avatar
I wouldn't throw it in park. I would just put it in Neutral and use the E-brake so the fluid keeps circulating through the tranny cooler. That is what I do. and tranny temps stay in check.
Old Aug 30, 2007 | 07:59 PM
wadediesel's Avatar
OK so you go to neutral and use E-Brake. So in Neutral the trans fluid still pumps?
Would leaving it in drive and setting the E-Brake simulate stop and go traffic or is that no good for the trans for long periods?
Would you recommend a trans temp gauge? If so which would you recommend.
Old Aug 30, 2007 | 09:56 PM
C4 Max's Avatar
More of a safety issue.
Old Aug 30, 2007 | 10:01 PM
wadediesel's Avatar
Yeah that I can see that.
Will it damage the tranny going in and out of drive that way?
Old Aug 31, 2007 | 07:30 AM
Christov's Avatar
I would just go to neutral as mentioned above. In park the pump does not operate, so your fluid will not be circulating in park to cool your transmission.
I would say neutral and e brake.
Old Aug 31, 2007 | 08:54 AM
wadediesel's Avatar
Thanks Guys for your Help. I'm New to Diesel trucks so all of the knowledge here will be great! Thanks Again
Old Aug 31, 2007 | 10:23 AM
ptgarcia's Avatar
A tranny temp gauge is a good idea. For that matter a full gauge set is a good idea. Pricol, Autometer, Isspro, Westach, or an electronic gauge like the Commander are all good products. I run a Commander and monitor tranny temp, engine coolant, EGT, and lift pump pressure at the same time.
Old Aug 31, 2007 | 07:57 PM
Christov's Avatar
It is my understanding that leaving the engine in drive and setting the brake will create extra wear on the clutch packs. I would think neutral would be the best choice.
Old Aug 31, 2007 | 08:07 PM
$oC@l CTD's Avatar
I say neutral and e-brake as well...but keep in mind that you will want to check the e-brake adjustment on a MUCH more regular basis than what is called for in the owner's manual which is 15000 miles...I think that your use of the e-brake would be considered pretty extreme...
ingramg
Feb 21, 2009 08:49 PM
97CTD
Jul 29, 2007 08:22 AM
Common
May 15, 2007 07:35 PM
slivertruck
25
Nov 8, 2006 08:35 PM
royta
Nov 6, 2006 08:19 AM
