Stock lift pump....time vs. miles
Old Feb 4, 2009 | 07:23 PM
Toto's Avatar
Mine went a couple of years ago at arround 65000 klm.
Intank replacement done with no further problems.
Old Feb 4, 2009 | 10:11 PM
SuperGewl's Avatar
With just under 100k miles I had my at the dealer to have it checked out prior to the warrenty going out. Mine was putting out less than 5%, they wanted $1200 to install an intank model. NOT
I bought a new one from E-Bay and installed it myself, I also installed a BD Low Fuel Pressure light. It also appears that the new pump is NOT performing up to standards because the light stays on most of the time. It might have to do with the use of 100% Biodiesel, so I am going to install BD lift pump as soon as it shows up. This shoudl ensure that I get a tleast 10PSI pressure at all times.
Get rid of your OEM pump ASAP if you don't it can kill your HPCR pump if you don't.
Old Feb 5, 2009 | 09:09 AM
jimmy_pop's Avatar
i have a 2004.5 with 125,000 and the OEM lift pump under the hood.
Old Feb 5, 2009 | 10:21 AM
xxwildbillxx's Avatar
Originally Posted by Riflemanusmc
91000. replaced it with Opie's belt drive pump. Didn't want to deal with another electrical part going bad on the road.
Wow...didnt know these exsisted for my 2003 Ram 5.9L! ...
1) What are the advantages/disadvantages of running a belt driven lift pump???
2) Does HP suffer at all?
3) What do these kits sell for & how hard are they to install?
Old Feb 5, 2009 | 11:02 AM
rogers259's Avatar
This thread might help you a bit:
https://www.dieseltruckresource.com/...d.php?t=231934
Old Feb 5, 2009 | 11:17 AM
RADSHOOTER -This thread might be of further help...
https://www.dieseltruckresource.com/...d.php?t=152569
Old Feb 5, 2009 | 11:48 PM
2006BLKMegacab's Avatar
Originally Posted by andyboland
Mine is original at 380,000 miles.
If your gettin that many miles outta one youre lucky, ive heard of alotta in tank pumps lettin go at alot less than tha for mileage, mine was gettin really weak at 50000 miles and 1540 engine hours so i had them put a new pump in, i'll give it one more chance in tank then i'll stick a FASS in it when im outta warranty
Old Feb 6, 2009 | 12:01 AM
annabelle's Avatar
128,000 miles.
Old Feb 6, 2009 | 05:41 AM
03RAM2500's Avatar
I replaced mine on my 03 in Dec. 08 at 110,000 miles. It was still working ok I thought but after replacing it with a AD 100, I could tell I had been low on fuel pressure at higher rpm's. The airdog was worth every penny and now I don't worry about when the stock one is going to die and leave me stranded.
Old Feb 6, 2009 | 05:54 AM
Hounddog's Avatar
I knew two 03 trucks that were traded in with mileage in the 150k range and still had OE lift pumps.Neither one of those trucks had anything go wrong.Two sets of tires and filters/oil etc.
Old Feb 6, 2009 | 08:41 PM
Asher's Avatar
The day I decide to go with an aftermarket lift pump, it will be a mechanical one. I have been holding off replacing the factory pump (currently at 90k trouble free miles) because the "electric solutions" out there (at the time) where less then perfect. To be honest I really suspect the these aftermarket electric pumps have no more life expectancy then a factory unit the only real advantage is that they "flow through" when they fail and the canister mounted pumps don't, and the AM LP's can make more pressure for added fueling purposes (that's the only advantage I see).
The CP3 is capable of pulling fuel through an open line, don't forget that the duramax CP3 (very simular to the dodges) don't even have a factory LP, it draws all it's fuel.
Here is a thread I started a while back and the information was amazing that came out of the responses and the funny thing was that NO ONE that makes / sells aftermarket LP's piped in or disputed the information...
https://www.dieseltruckresource.com/...d.php?t=227652
Sure the factory LP's fail, but so do the aftermarket electric ones but what is the failure rate 1 out of every 100,000 on the factory ones; and 1 out of every 2,000 on the aftermarket (I am really just guessing about the failure rates, but I see numerous post on here about AM LP failures)??? Really doesn't look like a solution/fix to me when it comes to realibility... Maybe some of them come with lifetime warrenties, but so did my "discount auto part store alternators" and sure enough they would be happy as could be to give me another one anytime the "lifetime one" failed ... but in the end I was the one with constant greasy hands and a broken car all they had to do was pull a new one out of a box...
I am sure my response will get hammered on but that's OK. You and I are in the same shoes (factory canister pump with decent amount of miles). What I am doing is budgeting for a mechanical pump, but NOT holding my breath until I get one. If I had a in-tank pump then I wouldn't even be concerned until I started having "high performance" issues due to lack of FP. To be honest I would love to see the amount of stock 04.5+ trucks that don't even have working LPs and people don't know it because the CP3 is pulling it from the tank...
Old Feb 15, 2009 | 09:36 PM
jennaspappy's Avatar
mine went at 192k 03 2500 with edge chip on since 30k.
Old Aug 15, 2009 | 02:27 PM
Afetr 192,000 on first pump second pump quite after 15,000 in the desert 80mile west of Needles CA and i was not happy. So I donot think time or miles just luck of who put part together.
Old Aug 15, 2009 | 06:05 PM
bekim's Avatar
kaput t 20,000 miles here.
Old Aug 16, 2009 | 11:36 AM
Equalizer 2's Avatar
I replaced a working factory filter mounted lift pump at about 50,000 miles with an aftermarket system to avoid any problems. At 80,000 miles I changed the fuel filter and found that the AM lift pump was dead. Needless to say I was not a happy camper, took half a day to find a replacement pump on a weekday. Currently have a Holley Blue running but need to find a back up pump and put in a pressure guage or light.
