Stock boost readings, and leaks?
Old Jun 29, 2007 | 03:09 PM
BMH95's Avatar
What are the normal boost numbers for a stock 05? I installed the boost gauge today, and am seeing no boost just putzing around, and max of 26, settling to 22-24 under full throttle (empty). Cruising at 55, I'm seeing 0 boost. What should I expect to see?
How would I know if I had a small leak at the boost bolt fitting?
Isspro 60lb gauge.
Old Jun 29, 2007 | 04:47 PM
rustyshakelford's Avatar
stock wot, i think i was around 32psi. cruising at 70ish is like 6-8 IIRC
brett
Old Jun 29, 2007 | 05:04 PM
torkmnstr's Avatar
I see 32-33psi wot, and cruising around 55 for me is about 0 as well, and about 70 is around 6-8 also
Old Jun 29, 2007 | 06:31 PM
BMH95's Avatar
Hmm. I think I saw a 30 spike for a split second on 3/4 throttle. There sure is no 32 at WOT though. I'll have to play with it. Can you over tighten the little compression fittings? Maybe that's my issue.
Old Jun 29, 2007 | 08:36 PM
torkmnstr's Avatar
No BM, I actually tightened mine on there pretty good and the tubing came out, so I cranked the crap out of it and there have been no adverse problems.
Old Jun 29, 2007 | 10:08 PM
phloop's Avatar
My stock '06 makes 36psi, as soon as the boost hits 36 it drops. And that is not at WOT, I am sure that it would do the same at WOT.
Old Jun 29, 2007 | 11:26 PM
speakle's Avatar
Thats good to hear phloop, I have been seeing 39psi at WOT and was really begininng to wonder what is wrong.
Old Jun 30, 2007 | 11:55 AM
BMH95's Avatar
Well then I'll tighted them up some. I may not have tightened the gauge end very well at all. Do I need to seal the boost bolt with anything? Teflon on the threads?
Old Jun 30, 2007 | 02:46 PM
phloop's Avatar
I believe that the bolt seals to the manifold with the under side of the bolt head not the threads. If it is leaking try finding a soft copper washer to put in between the bolt and manifold, that will help seal it. Try one of the copper washers that is used in between the brake hose and the caliper on a disk brake system.
Old Jun 30, 2007 | 10:50 PM
JuzPlaneKrazy's Avatar
My 06' truck running stock runs 32-35 WOT, a little more with the XZT 55mph its around 7-9, Zero with no thottle at all.
Old Jul 1, 2007 | 06:27 PM
DECEPTiON21's Avatar
I see around 30 at WOT. As to the compression fittings... You CAN over tighten them. I did it a few times with my fuel pressure gauge and it tears the heck out of the tubing and the brass nut that compresses.
Old Jul 1, 2007 | 11:36 PM
torkmnstr's Avatar
Dang fella, 39 psi, mine hits that with boost fooler now, but not even close without!!
Old Jul 2, 2007 | 07:49 AM
speakle's Avatar
I have been asking about that on 2 different forums and no one knows anything about it. Only answer so far is that the edge even set to stock does boost fooling.
Old Jul 2, 2007 | 08:40 AM
BMH95's Avatar
That's what I'm wondering, the "stock" settings on tuners / boxes / programmers still doing boost fooling. I'm totally stock, and I saw a brief spike at 30 while merging on the highway last night, but at WOT it typically might peak between 26 and 28 before settling down 2 or 3 psi. Also, I was running at 3-4 lbs at 69mph. This is flat road with 373 gears, and auto, and 285's. I can see the wastegate opening, so I'm wondering how much vairation there is in what the computer sensor sees. Maybe the map sensors are too widely tolerant? Also, what are people using to see boost numbers (gauge). It seems that I'm reading most people with Edge products read higher boost numbers that those with analog. Maybe it's an edge marketing trait?
Old Jul 2, 2007 | 11:03 AM
torkmnstr's Avatar
BM, I am using an Issopro 6o psi analog guage.
