Steering wheel crooked and wobble
Old Feb 5, 2009 | 12:49 AM
redneckwilly's Avatar
So on new years day I decided I would drive 135km/h on gravel just like usual but this day it was a little icy. I ended up hitting the ditch at about 60 to 70 km/h going through a fence that I had built this year and ended up being alot stronger than I thought it was. 14,000$ later in body work and she looks like new but there is a slight wobble in the front end at about 50 km/h to highway speed. I stuck my head out the window and noticed the wheel wobbling a little and my steering wheel is on a 60 degree angle. Im thinking alignment, u-joint, possibly even a bent rim? Its going to the dealer friday but I would like a heads up if possible...thanks in advance
-Mike
P.S. With the new paint im only going about 20 on gravel
Old Feb 5, 2009 | 01:07 AM
bradler's Avatar
wow, you would be lucky if you just bent a drag link on the steering linkage. I would start with balancing the wheels, then see if it aligns. U joints won't make the wheel wobble. Maybe separated the hub a little causing the wheel to wobble, but hard to tell. Hope you didn't bend anything else but if so i would show up during alignment. personally i would go somewhere other than dealer first for alignment...
Old Feb 5, 2009 | 01:11 AM
The alignment and inspection will be covered by insurance and anything else that shows up possibly. Its a very slight wobble and the truck is not wandering so im not thinking anything too serious or I would have been able to tell so far I think.
leeboy
Feb 8, 2011 04:34 PM
93 high hopes
Jan 15, 2011 02:14 PM
u.s mma
Feb 13, 2009 02:49 PM
DodgeRamdiese01
Aug 14, 2008 07:38 PM
Lundee
15
Feb 7, 2008 11:28 AM
