Squeak?
Old Dec 2, 2009 | 09:15 AM
pluguglyinhere's Avatar
Squeak?
I have a squeak and I mean like a mouse squeak, very rythmic meaning not intermitent at all goes with rpm unitl about 10-15 mph.
It will only do it if the accelerator is applied or brake applied. I can hear the noise start, let off the pedal so I am coasting it goes away, apply the brakes or accelerator and it is back.
If I shift to nuetral, the noise goes away, then I can rev the motor and no noise, and if I apply brakes while coasting it comes back.
I was thinking u-joints until I saw a post from searching about rear brakes doing this. They needed some scuffing and a little emergency brake work.
I also saw from a search that rear springs cam make a squeak?
Any thoughts?
Old Dec 2, 2009 | 02:09 PM
SOhappy's Avatar
Sounds just like my u-joint squeak. Crawl underneath and check for play and look for rust around the yokes seals.
shep1
Aug 29, 2010 10:19 PM
CTD2001
15
Nov 28, 2009 07:54 PM
ytodd
Nov 2, 2007 09:57 AM
gman07
May 9, 2007 06:03 AM
hotdram
31
Sep 17, 2005 08:00 AM
