Spring pack noise - Air Bag Related?
Old May 31, 2010 | 10:15 PM
tallboy's Avatar
Hey guys,
I recently installed some pacbrake air bags and now I noticed there is a noise from the springs when I hit a crack in the road. I found the overload spring u-bolts are loose, the fronts worse than rear. When I tried to tighten the bolts, they were still able to move around if I tapped it with the wrench. I didn't want to crank it down too far thinking that would make the ride worse. I also tried running the bags at 12 psi to see if that would help but it didn't. Any suggestions?
Thanks,
Conor
Old Jun 2, 2010 | 11:32 AM
jballou's Avatar
Your u-bolts are still not tightening the pack on to the axle. There either isn't enough threads on the u-bolts and the nut is at the end of the threads or you need to find the issue.
Running around with loose u-bolts is a disaster waiting to happen. They keep the axle and spring connected, imagine if they shifted around alot suddenly while driving.. Bad.
Old Jun 2, 2010 | 08:57 PM
tallboy's Avatar
The main spring pack is tight, it's the overload spring u-bolt that wiggles a bit. There is plenty of thread left to tighten it, I was just concerned that cranking the preload on the overload would result in a crappier ride.
Lonepine78
Sep 25, 2013 10:57 AM
tauberson
May 2, 2008 08:59 AM
abc4yew
Apr 24, 2008 03:17 PM
Joe T
16
Jun 12, 2007 12:11 AM
PZM123
Feb 5, 2007 06:01 PM
