something's broken- front end ?s
Old Jul 13, 2007 | 07:10 PM
trackstarrdb's Avatar
I'm not sure if this is the right forum, cuz i'm not sure what's broken yet. Hopefulley somebody can help me... My truck was sitting for a few days, and when I first turned out of my driveway the steering wheel jerked back in small increments. I jacked it up and spun both front wheels, they were both ok when straight, but at full turn the driver side ran smoothly, but the passenger side was harder to turn and seem to stick at a certain point... Wheel bearing/hub or axle u-joint? I don't know enough (obviously) to figure this out just by searching through old postings... Thanks for any help... -RYAN
Old Jul 13, 2007 | 11:11 PM
rjm022's Avatar
from the description-sounds like a possible wheel bearing-which would be the hub aseembly. did you move the wheel at all for any other possible problems?? up and down, would be ball joints. side to side could be tie rods. does the wheel in question make any kind of noise when driving/turning??
Old Jul 14, 2007 | 05:13 AM
papaduck's Avatar
It is your axel U-joint. Stright ahead the u-joints do not flex, so no jerking.
Replaced mine recently. Had the same problem as yours before replacing the joints.
I posted a detailed how to at this thread:
https://www.dieseltruckresource.com/...t=axel+U+joint
Old Jul 14, 2007 | 10:43 AM
There's no side to side or up/down movement really. u-joints were sorta what i was expecting... just did ball joints 3k miles ago, i wish i could have seen this coming, it would have been nice to do it all at the same time... Thanks, I guess I'll go tear it apart... again...
SkinnyBTN
Jul 13, 2008 03:51 PM
89dieselkong
Apr 17, 2008 07:39 PM
Rpainter
21
Mar 8, 2008 02:36 PM
Gordonville
Apr 18, 2005 09:45 AM
