Some information please
Last Saturday, I was heading north from my place to do some halibut fishing with a couple of friends. While going down the freeway, my truck just flat died. I was able to coast to an off-ramp and on to the other side, where I waited. I tried to start it a couple of times, and it would run for about a second, then die. I figured to myself that the lift pump finally died. I was towed to a dealer just 11 miles away.
On Monday, I was in the area for work and swung into the dealer and talked with the tech who diagnosed it, and I was right, the lift pump was dead. He pointed out a few other things he found in his inspection, such as needing a computer re-flash and a leak between the tranny and transfer case. I gave the ok to do that work.
My question concerns the re-flash. He said I had version AH and the re-flash would be version AN. Is there any place I can go to find out what the re-flash actually does? Any ideas as to what the re-flash does?
By the way, the truck has 167,000 miles on it, and this is the first real thing to go wrong with the truck. I do the normal maintenance on it myself. It is mostly a daily driver, with one or two times a year towing a fifth-wheel, but only for the last couple of years. Before that, I would carry a p/u camper and tow a boat once a year.
Any help would be appreciated.
Thanks,
DMH
Thanks,
DMH
I don't know the answer, but maybe it shows up here if you want to look through the various TSBs listed as flashes for 04 models.
http://dodgeram.info/tsb/2004-index.htm
Alternately, just call the dealer and ask.
Good luck!
Good luck!
I'm normally a big fan of dealer re-flashes but in this case be advised you'll get the back -up alarm "feature" (if you don't already have it) that you 'll absolutely loath...
A good dealer will warn you about it before re-flashing.
Also, I assume you have the engine-mounted lift pump and they are moving it to the tank? There are other options.
kingofdodge7131
Jan 15, 2010 07:50 AM
RCinMesa
Dec 19, 2009 07:55 PM
dmt58
Jan 28, 2009 06:46 PM
