smoke coming from blowby tube back of block
Old Apr 2, 2010 | 05:55 PM
alltimelow1's Avatar
Guys,
I am noticing some smoke and a small drip of oil or 2 from the vent tube on the back of the block drivers side. I change the oil every 5,000 miles and have not had to add any oil in between oil changes yet, I am wondering if this may change this next oil change, we will see. It runs just like it always has - I notice some light smoke from tailpipe and some occasional hard start after running it that I attribute to a not-100%-injector but, hasnt caused me enough worry to change injectors - please let me know if you think this is a sign of my injectors going
My question is what is causing this and should I be worried or do something to remedy it?
Truck has 190,000 miles now and is a 'pleasure' truck - which means I drive it like 7,000 miles a year for hunting and pulling my wifes horses around (this would be the important part because if it breaks down then its my fault!)
Any info is greatly appreciated - Thanks!!
Old Apr 2, 2010 | 06:46 PM
mastertech's Avatar
to long idling will cause that to happen
Old Apr 29, 2010 | 06:06 AM
Thanx
Old Apr 29, 2010 | 09:03 AM
CD in NM's Avatar
Isn't that blowby tube connected to a filter? If so, maybe you need a new filter? I recall a post some time ago discussing this, it did have a fix, some kind of bottle attached, lengthening of the tube?? I think the dealerships have them or can tell you how to fix it??
As long as your truck is not making oil, as in fuel going into crankcase, your injectors should be ok.
CD
Old Apr 29, 2010 | 09:22 AM
Dodgezilla's Avatar
That tube is there for a reason. As long as you are not constantly leaving a puddle of oil under the truck you are probably OK. My truck smokes from there too so I ran a hose all the way to the rear bumper so I don't have to smell it anymore. I run Rotella and it stinks bad. I'm gonna switch to Mobil Delvac on my next oil change and see if the smell goes away but I'm keeping the hose there either way. My truck has less that 44000 miles on it too.....
Old Apr 29, 2010 | 09:46 AM
Hillcountry's Avatar
Just make sure if you re-route the blowby tube, that it always "flows" down hill and has no low spots where a blockage can be made. The tube needs to be constantly free flowing otherwise you will build up crankcase pressure and blow seals.
Old Apr 30, 2010 | 04:46 AM
Dodgezilla's Avatar
This correct and it's very hard to do. My hose is 3/4 ID so it would take a long time to build up that much oil but I have considered piercing it in any low spots so the oil could drip out if it built up......
dr.caterpillar
Jun 14, 2009 04:33 PM
Dean Snow
Sep 21, 2007 01:18 PM
judge88
Jan 18, 2007 08:20 AM
gsoutherland
Dec 25, 2006 06:34 AM
bluesfan01
Nov 16, 2006 08:07 PM
