Line pressure adjustment
Minimal impact from what I have seen. Its like 3 lbs per turn and you can only get 4-5 turns before you run out of adjustment.
These transmissions need a 30-40 psi bump on the bottom end and 70-100 psi on the top end to get the line pressure where it will do any good. You need the right springs to do that. The adjustment is just to fine tune things.
Worth a try. I have tried it a couple times and I really could not feel a difference. Might have had more wear or other problems that interfered also.
RoadDiesel
Jun 16, 2007 09:24 PM
SSweeney
Oct 7, 2006 07:01 AM
Begle1
19
Aug 25, 2006 11:31 PM
Flatty
Jan 5, 2005 02:50 PM
