Smell sweat/ gear oil in cab
Old Feb 14, 2008 | 11:48 AM
FishingFather's Avatar
Happens to me occasionally when I get home and pull into the driveway, smells like my sons feet! I have been told it is the fumes from the oil I use. I don't see any fluilds leaking or levels going down; the smell isn't constant either, just occasional after pulling in after a long drive. Got almost 90k miles and no serious issue. If you find a problem related to it please post it up.
Old Feb 14, 2008 | 09:38 PM
CrazyCooter's Avatar
Are you smelling oil vapors coming from the draft tube?
I notice more smell right after I change the oil.
Old Feb 14, 2008 | 10:20 PM
dozer12216's Avatar
Look carefully for a oil saked rag with gear oil on it. Common prank.
Old Feb 15, 2008 | 02:12 PM
corygale's Avatar
I wish it were a joke, but no i can see fluid on the chassis just cant locate where it is coming from I see two lines running maybe one of them ill have to clean and keep my eye on it just stinks like hell
Old Feb 15, 2008 | 02:20 PM
vzdude's Avatar
DTR's 'Go to Guy'
Get a picture of the fluid , where it is on the chassis. It has to be coming from somewhere. Get a fairly wide shot, so we can see better where the location is.
Old Feb 16, 2008 | 05:03 PM
gbpeay's Avatar
Now that it has quit snowing here in Utah I had a chance to look around a little more. The smell in mine is the engine oil. I pulled the dipstick and WHOAAA, that's the smell. Not sure what brand it is because I just bought it two weeks ago. The oil is full and I don't see any leaks, must be venting somewhere around the cab.
Old Feb 16, 2008 | 10:32 PM
MoparNut's Avatar
Do you smell it only when the engine is running? It may be the exhaust. The exhaust on my 06 smells kinda sweet....in-a-burnt-diesel-fuel-thru-catalytic-converter kinda way.
Check for a exhaust leak.
Also a leaky battery will smell kinda sweet.
Old Feb 17, 2008 | 10:14 AM
corygale's Avatar
again its sweat not sweet no spealling error but thanjs for all the knowledge guys muchly appreciated
irocpractice
Jan 27, 2012 06:19 PM
EdmontonCanada
22
Apr 14, 2011 05:41 PM
jaroban
14
Dec 22, 2006 09:16 AM
Ghost Ram
Nov 27, 2006 11:46 AM
INsIdious
May 5, 2004 04:14 AM
