Small ATF leak from front of built tranny
Old Jan 9, 2008 | 04:19 AM
chris.willis.68's Avatar
Gents:
I recently had my tranny built with a Goerend VB and triple disc clutch and billiet input shaft. Done at the local Dealer. They installed a Mag Hytech DD pan on the tranny.
In the am when I pull out or after a long ride there seems to be a couple of drops of atf on the ground just under the bell housing.
My questions is... Does the tranny eject atf when slightly overfilled?
PS The tech who built my tranny has done 100s of them (not a good sign is it) and replaced all seals etc.
Old Jan 9, 2008 | 10:09 AM
bluebull's Avatar
Some times even highly qualified mechanics make an error. You have a leaking pump or seal. Take it back, show them the leak, if their a reputable business they should take care of you for nothing.
Old Jan 9, 2008 | 07:07 PM
The appointment has been made for Thursday next week. More information to follow.
Old Jan 10, 2008 | 12:42 AM
Shagginwagon's Avatar
Are you sure its ATF? Could it be antifreeze? There is an overflow tube for the antifreeze that has two clamps that are known to become loose. Look in front of the bell housing on the passenger side. There will be a tube about 1" diameter (?) with two clamps. Just a thought.
Old Jan 10, 2008 | 12:46 AM
Det 1's Avatar
There's also a seal where the filler tube connects to the tranny. I had a leak a few months ago and that's where it was coming from. Easy fix.
Pig
23
Jun 4, 2010 01:01 PM
Shank
41
Jan 9, 2008 11:03 PM
Mslaughter
Aug 24, 2006 06:44 PM
dieselfan
Aug 5, 2006 10:44 PM
Pig
Mar 13, 2006 09:12 PM
