Slippery When Wet
I see that a lot... Nitto's have great traction in their AT's. If you get hung up in some wet grass, drop the air pressure down to 30 psi, it'll help a lot. Just remember that you have to drive real slow to somewhere you can get air after that.
I currently have 20k on my Michelin AT2's and really like them. I put 60k on the stock Michelins but hated how slippery they were.
The AT2's will be a little more road noise when the windows are down but not bad. You have 2wd but would notice a big inprovement with the Michelin AT2's.
Michelin LTX tires are (IMO) the best light truck tire on the market. No troubles with balancing, last a long time, E rated.
AT's have a great tread pattern. When the conditions get rough, they'll really dig in and get you moving. The downside is that they're a little noisy and slightly rough on dry pavement.
I prefer the M/S tires. A great tread pattern that really digs in. But still quiet and smooth on the highway. It's a good comprimise between the standard street tire and the AT.
When you get a wheel spinning, apply just a little bit of brake. It works like traction control, and will help control the spin so you can dig in. If you have a manual trans, start in 2nd gear.
+2 on the AT2's...
Just put them on and they are night and day better than the stock A/S's
Rick 12v CTD
Jul 21, 2009 10:54 PM
trailblazenyj
Mar 14, 2003 11:18 PM
, I have HWY. tires on my 2wd truck they are useless I get stuck on wet grass. What tires do you guys suggest for a little more traction.
