slinging codes and running rough
Old Jun 20, 2012 | 09:08 PM
texasdayworker's Avatar
I'm throwing:
P0251 CP3 Pump fuel Regulator Control
P0191 Fuel Rail Pressure Sensor Performance
P0236 Turbocharger Boost Sensor A Circuit Range/Performance
Truck is running rough, as you would expect. What have yall experienced with these codes? I have read all kinds of things and I am still researching, just thought I'd ask. Thanks for any help.
Old Jun 21, 2012 | 08:38 AM
jhenson's Avatar
The FCA controls the pressures from the CP3....if it's going haywire it can spike pressures and possibly give the rail pressure code.....will also cause the truck to run very funny....$100 part from a Cummins shop or you can visit www.genosgarage.com
Hope this helps.
Old Jun 21, 2012 | 10:13 PM
Thank you sir.I appreciate the help. I'll try that and hopefully it works. Any idea on how hard the FCA is to change?
Old Jun 22, 2012 | 08:20 AM
jhenson's Avatar
It's just 3 Torx screws. Tap them a bit to try and "loosen" them up as they are installed with Loctite. Maybe a 15-20 min job.
Old Jun 23, 2012 | 12:02 PM
Thanks!
Old Jun 23, 2012 | 12:07 PM
jhenson's Avatar
Not a problem sir. Keep us posted on how it turned out for you.
exwrestler
Feb 5, 2010 09:34 AM
sallyman1
Aug 26, 2008 06:20 PM
Swamp_Donkey
Mar 15, 2008 12:59 AM
mbenedict
Jul 21, 2007 09:19 PM
