Slight oil drip, front of engine
The title says it all, I saw a small drop of oil on the driveway the other day (first time) and sure enough I see a tiny drop now forming under the front of the engine
I'm not that familiar with the 5.9L design but if I'm not mistaken if it's like most engines the only thing that could cause that would be a front engine seal? where the front damper pokes through the engine.
Just what I need
I'm hoping there are other issues that could cause this, it's certainly not a big leak, there is no observable drop in oil level. The engine only has 80k on it and I'm running a older Bully Dog in tow mode with HD torque converter and valving.
And if it is the front seal is it a big deal to fix money wise?
Any thoughts would be welcome as would any $ contributions.
Ron W.
Just what I need
Ron W.
Are you sure it's not just the crankcase breather tube? Driver's side of the engine, probably back about 2 - 2 1/2 feet from the bumper? If it's the breather tube, welcome to owning a 5.9L Cummins... You should be able to see the breather tube if you slide under the truck. I've found the amount that drips out of there is in direct correlation to how much oil you have in the truck. Pretty much anything over 11.5 quarts in my truck will cause it to drip a little bit, especially after long or hard runs.
The leak could also just be the timing gear cover bolts being loose but I can't see how you can get to most of them with out doing the front end removal.
Some people have mentioned the seal behind the vacuum pump attached to the power steering pump???
Whats the chances of that being the issue? I can't even peek behing there either to see.
Ron W.
BearKiller
Jul 11, 2022 02:43 PM
dslpwr81
28
Jan 26, 2009 09:08 PM
b4wheeler
Apr 18, 2007 03:54 PM
Common
Sep 19, 2006 05:27 PM
