Slight changes to 03 engines
Old Oct 9, 2003 | 03:54 PM
mymaur's Avatar
I just traded my 03 that I bought in March for another new 03 last week. Was out looking at the engine today and noticed a few changes.
My first truck was manufatured in Oct 02. The engine ID tag was on the throttle body and the throttle body was rounded on the front. The new truck was manufactured in July 03 and the throttle body is now square shaped and the ID tag is a sticker on the valve cover, drivers side. What does this mean? NOTHING, just worthless info.
Also, check your Auto trans cooling lines. Mine are touching and will eventually chaffe thru. I just cut some old heater hose and put it between them. These hoses are on the drivers side, under the throttle body. Two large hoses, can't miss em.
Check your AC lines as well. They may be touching, or very close, as they make their way to the condensor. If they are close or touching, they bend easily. Just move them apart. In time, they will chaffe thru. When my old 95 did this, it was a $500 repair.
For people wanting to know what the valve lash adjustments are. These are also on the ID Sticker, and are the same as they have always been. I'll get them and post em later, raining out now.
Old Oct 9, 2003 | 04:08 PM
JKE's Avatar
JKE
Re:Slight changes to 03 engines
mymuar - my current truck is the same config as your new one. We are going to deal on that truck tomorrow for the wife. I will check this stuff out also.
I think that was good info.
John
Old Oct 10, 2003 | 07:54 AM
Sittenbull2's Avatar
I will be checking this also.This is the kinda of info. everyone needs. My truck build is Feb.23,2003 the engine is the same I suppose. I can't find no other build date unless someone can tell me where to look. mymaur mine is built the same as yours, will be looking for the AC lines this weekend.
Thanks once again mymaur
Sittenbull
cbx
May 18, 2009 07:23 PM
sallyman1
Jan 27, 2009 10:33 AM
Common
Sep 19, 2006 05:27 PM
Tackdriver
Mar 31, 2003 11:06 PM
