Single Steering Stabilizer
Old Apr 28, 2009 | 12:14 AM
D45's Avatar
D45
I currently am running Skyjacker's dual front steering stabilizer kit.
With the front Mag Hytec diff cover, there no way the two will work together.
I am taking off the front dual stab kit and want to look for a high(er) end single stabilizer.
Fox, King, Fabtech......any suggestions?
The King from Don Thuren is about $265, and clamps onto the steering rod:
http://www.thurenfabrication.com/ramstab.html
I like the Fabtech, because it bolts into the stock locations, and is a Dirt Logic brand for $230
Defiant has the Radflo 2.0 for about $220
http://www.defianttruckproducts.com/...y_part/275.php
Defiant also sells another for $170
http://www.defianttruckproducts.com/...y_part/128.php
Anyone else make a good, heavy duty unit?
Old Apr 28, 2009 | 08:45 AM
enafzige's Avatar
Carli makes a high mount bilstein stabilizer, which keeps it out of harms way. They also make a bilstein replacement for the stock location. Both are very high quality and are nitrogen filled 7100s.
http://www.thecarlisuspension.com/do...tabilizer.html
--Eric
Old Apr 28, 2009 | 11:13 AM
Pull Ya's Avatar
Suprisingly a lot of people think that the stock stablizer does an excellent job. I think they are better than a lot of the high dollar ones. I had a Rancho and it was a piece of crap. When I went to the new steering kit I used the stock stablizer and it does a great job.
Jay
Old Apr 28, 2009 | 03:03 PM
Clane's Avatar
KORE has a similer set up like Thuren's for.... wait...ouch...nevermind...
http://www.koreraceshop.com/kore-rac...ng-damper.aspx
Old Apr 29, 2009 | 01:37 PM
D45's Avatar
D45
From Don Thuren:
"Honestly, those MagHytec front covers cause a lot of clearance problems, so I usually suggest not running them. Even my single Fox stabilizer will not clear that cover. Function wise, my single fox is about 4 times as effective as your dual SJ kit."
Atleast he is honest!!!!
I know the Dirt Logic will clear, because it utilizes the stock mounting locations.
It seems like to the majority of the aftermarket line clamps onto the steering rod, and are typically longer than the bolt on versions, which must cause the clearance issues when using a front MH diff cover
Old Apr 30, 2009 | 01:28 AM
banana's Avatar
--Eric
I have the carlio one... Works great and was easy to install! I also installed a BD steering box stabilizer at the same time...
mercedeezel
13
Oct 13, 2013 12:43 AM
WUnderwood
15
Jan 29, 2009 12:26 AM
Rattlerattle
Aug 19, 2008 04:14 PM
13ALPHA
Jul 8, 2008 11:31 PM
yelloz28
Mar 20, 2008 04:16 PM
