single or dual disk???
Old Dec 15, 2011 | 10:35 AM
Bret66's Avatar
Ok, Ive read through past posts concerning clutches and really havent found the answer... Is a dual disk necessary? I dont plan on modding my truck.. I've put 155,000miles on stock clutch.. I spoke with someone at Valair and was told that dual disk organic was the only way to go.. what are your thoughts.. Need to replace the DM flywheel, before the throws some weights through my bell housing..
Thanks,
Bret
Old Dec 15, 2011 | 02:25 PM
Lary Ellis (Top)'s Avatar
Admin Team Leader
A dual disc for a stock truck is overkill, any salesman that tells you otherwise is only after your money.....
I would go with a single from SouthBend, the Con O is a great fit if you are not going to mod your truck any....the Con OFEK is even better and will give you wiggle room for some mods and still have the basic manners of a stock truck.
When you are ready give me a call and I will NOT try to sell you something you don't need....
Old Dec 15, 2011 | 03:35 PM
Bret66's Avatar
Thanks for your honesty.. I was kind of thinking the same thing. ill give you a call.
Old Dec 15, 2011 | 06:46 PM
Gemstone's Avatar
The single disk 1947 OFE is what South Bend recommended for my '05 3500, 6 speed, towing 10K with a mild chip.
Regards
Gemstone
mhuppertz
Apr 3, 2010 05:14 PM
winkdemon
Aug 3, 2009 04:13 PM
cconrad331
Jan 27, 2008 09:47 AM
DSjockey
34
Jul 20, 2007 07:03 PM
Mav
Dec 24, 2005 12:06 PM
