Silencer ring?
Old Nov 21, 2005 | 09:07 PM
Pwr Generation's Avatar
Silencer ring?
Heard of it on posts, but no direction on how to remove or where it's located at exactly. Does it make a noticeable improvement?
Old Nov 21, 2005 | 09:24 PM
slimpicken's Avatar
the silencer ring is a little aluminum or ss jobber that sits right at the mouth of your turbo to provide a smooth entry way for the air coming in. It is held in place by a snap ring that is somewhat of a PITA to get a screwdriver under as its hard to see which end is slanted the correct way to get the tool under. even so it maybe a 30 min job. just take the intake hose off the front of the turbo and go to work. Be carful to stay off the impeller blades as they are coated with a powder that balances them out. it does make the turbo louder with no apparent neg or pos side effects. I took mine out within the first week or so I had my truck because I couldn't stand not having some sort of noise coming from under the hood of my diesel truck. Well worth the time just to get under the hood if nothing else. Note: if you don't have any other mods done to your truck it will not make the turbo that much louder. Hope this helped.
I'm gone to thanksgiving, Peace
Nick
Old Nov 21, 2005 | 09:39 PM
handymantim's Avatar
After I removed my silencer ring I didn't notice much of a difference in sound until I removed the baffles from the intake tube.
FWIW, I did a search for "silencer ring" and came up with 500 posts. This topic has been covered extensively.
RonP
Feb 17, 2010 09:30 AM
RRC
May 13, 2007 11:45 PM
HaulinBut
May 12, 2006 03:06 PM
StrokeThis2500
Dec 31, 2005 05:19 PM
