Silencer Ring?
Re:Silencer Ring?
Howdy,<br> Why yes it does
. And it also features noise reduction in the big black plastic tube on the intake side of the inlet air plumbing >
. Mine lost both due to my carelessness with a screwdriver and hack saw ;D. Jeff
Re:Silencer Ring?
you will need 2 screw drivers and a needle nose pliers set.<br>take a very small (but strong) screwdriver and gently force it under the edge of the snap ring to raise it slightly out of its retaining ring on the turbo. As you lift up on the edge take the second medium sized screw driver and force the raised edge of the snap ring away from the turbo. Using the medium sized screwdriver to hold the snap ring away from its seating area on the turbo use the needle nose pliers to grab the ring and pull it on out of there. The silencer will usually fall out at this point and make sure there are NO metal shavings in the inlet after you are done your surgery doctor 8).<br>Jeff
Re:Silencer Ring?
Is it true that removal of this feature voids the warranty?<br><br>If not, where is this noise reducer found?<br><br>BTW: I am a turbo man. *whistle while I work*
Re:Silencer Ring?
No It does not.
In the black plastic tube between the air filter and the turbo inlet. Its in the straight section. Once you cut it out it can't ever go back in unless you buy a new tube. And quite frankly I don't see that need ever arising
.Jeff
Jeff
Re:Silencer Ring?
If you remove the plastic air defuser properly you can reinstall it. ;D I did no problems 8)<br>I removed the silencer ring with one screw driver. It came out real easy 8)
Re:Silencer Ring?
[quote author=BRDIESEL link=board=20;threadid=8857;start=0#99111 date=1044071462]<br>
If you remove the plastic air defuser properly you can reinstall it. ;D I did no problems 8)<br>I removed the silencer ring with one screw driver. It came out real easy 8)<br>[/quote]<br><br>You were able to remove the plastic "+" section from inside the large black tube without destroying it ??? ???. How? Mine was glued in the middle and there was no way to get it out intact so out it came with a hacksaw blade. ;D<br>Jeff
Re:Silencer Ring?
8) Remove the tube from the truck. On the inlet side you`ll see the lip that is on the end. I used my die grinder and cut the flang/lip off the end. This allows you to reuse the tube and not worry about the sealing to the boot. Anyway cut off the end lip, take a hammer and tap the defuser out with the handle end. Clean the tube and reinstall. Make sure you remove only the lip that holds the defuser in. Not the HACK saw methode. You can`t tell it`s been removed unless you remove it and look inside. ;D
