silencer ring
Old Apr 4, 2007 | 11:28 AM
Buffman88's Avatar
silencer ring
im having a little trouble getting to the turbo so i can remove my silencer ring. is there an easyer way to do it? and i saw some of yall were saying that removing somethign else would make it louder too?
Old Apr 4, 2007 | 11:46 AM
PEAKSTRYDE's Avatar
Pull the intake tube off and you will see the silencer ring inside the turbo. Take a small flat head screwdriver and carefully pry out the retaining ring. The silencer ring will fall out into your hands.
Clickly for Intake MOD!!!
Old Apr 4, 2007 | 12:14 PM
gscmiller's Avatar
Any damage done to turbo/motor by doing the ring removal? Any gains besides the sound?
Old Apr 4, 2007 | 03:08 PM
Buffman88's Avatar
i removed the silencer and the black thing (muffler or whatever it is) its a great sound... but will this void my warrentry and will it cause problems later on down the road??
Old Apr 4, 2007 | 03:50 PM
torkmnstr's Avatar
Buff, I dont think this will void warrenty because there is no reason that a tech should need to take your intake tube off. Keep the ring and reinstall it when you take it in, if you really want to be sure. Get an afe stage 2 intake, that will allow full air flow and sound from the turbo, trust me it sounds and looks sick when you pop the hood and see that HUGE filter element. There are white internal air baffels that direct the air to the turbo, remove those if you want to keep the stock air box, and that will give you more sound. Hope this helps
RonP
Feb 17, 2010 09:30 AM
RRC
May 13, 2007 11:45 PM
HaulinBut
May 12, 2006 03:06 PM
StrokeThis2500
Dec 31, 2005 05:19 PM
