Shutter?
Old Jun 23, 2006 | 01:53 PM
HappyGA's Avatar
Shutter?
When I take off, sometimes I feel a shutter. It does not really do it when i drive it straight, but I feel it when I turn. Keep in mind this is only when I am taking off, not after it is going? Could this be torque converter shutter?
Anyone have any ideas to what it could be? I would think if it was in the tranny, it would always do it when taking off, and not just some of the time. I was thinking it was the limited slip, but I dunno. I am a little confused, and do not want to throw money at it, like having the bands adjusted, which might be due anyway. I jsut hit 70,000, tranny warranty just went out .
I need to have this seen about or have an answer to it, because I am supposed to pull a luggage trailer to the TN mountains in two weeks for our youth trip.
Had this truck for three weeks, and it started it like a week after I bought it.
Old Jun 23, 2006 | 02:00 PM
JD Dearden's Avatar
When I lifted mine it would do this and I took it back in and I think they shimmed something and it fixed it?
Old Jun 23, 2006 | 05:04 PM
sticky's Avatar
It's usually a driveline angle issue or worn U joints. Try shimming the carrier down about 1.5" and see if it helps. Check the U joints for play while your under there.
Sticky
Old Jun 23, 2006 | 08:58 PM
phloop's Avatar
Maybe you might think about cleaning the truck out if your feeling shutters. Did some window work lately?
I think the term is shudder. Or have we changed the meaning here?
Old Jun 24, 2006 | 07:35 PM
roadrat's Avatar
Here is a tsb for what you are describing for the 03 trucks with 2 piece driveshaft. They call it launch shudder. not sure if the short box has 2 piece shaft.
http://dodgeram.info/tsb/2004/03-003-04.htm
rob
Old Jun 26, 2006 | 07:34 AM
HappyGA's Avatar
Thanks for the TSB,
My truck is 1000 miles out of drive train warranty. 71,xxx on it. grrreeat
Old Jun 26, 2006 | 09:08 AM
scottrod's Avatar
My 06 seems to have the same issue. Guess I better take it in
Old Jul 6, 2006 | 04:28 PM
Crashmonster's Avatar
I have an 06 mega cab. When it was at stock height, I could feel a slight shudder when taking off. After I lifted it 6" the vibration was terrible. I ttok it to les schwab and the installed a carrier bering kit that smoothed everything out.
Old Jul 7, 2006 | 03:35 PM
HotRodK's Avatar
Cool
My '06 is stock height and stock tires and I can feel exactly what you are describing. I guess its time to take it in.
mikie1234
Jan 5, 2005 12:11 PM
mikie1234
Dec 25, 2004 12:54 AM
lab
Jul 25, 2004 07:45 PM
BLUTIC
18
Apr 17, 2004 06:17 PM
steveb
Jun 16, 2003 01:04 AM
