Shudder while towing with 6 speed
Old Jul 1, 2003 | 04:53 PM
Haulin_in_Dixie's Avatar
Re:Shudder while towing with 6 speed
My '99 has done the shudder since it was new with a heavy load. The heavier the load the worse it is. When I changed to the six speed and shortened the front shaft six inches, it became a little worse. I believe that it is the blocks spacing the rear from the springs. They are angled properly for smooth running, but when under heavy torque, the springs wind some causing a misalignment. Will it hurt the truck? I have 205,000 miles with the original ujoints, center bearing, and rear. The trans and clutch have been changed to upgrade. See sig.
Old Jul 1, 2003 | 09:19 PM
FiverBob's Avatar
Dixie Man,<br>Are you finding this only in the low gears, like 1st or possibly also second. It sure feels like something does not like all that torque when it is loaded. I don't pull what you do, but I am pushing 16000. It is very annoying for a new truck to do this that is supposed to be so strong and ready to tow this much weight. Again, so much for good testing under all circumstances before releasing the product. :'(
Old Jul 1, 2003 | 09:28 PM
cp's Avatar
cp
Bob, I thought you got that fixed? Weren't you the one who got the whole new flywheel, pressure plate, and clutch?<br><br>Some gear trains have a resonant frequency down low that simply can't be avoided. I've had many trucks that would make a racket if you lugged them below a certain point.
Old Jul 2, 2003 | 03:26 PM
FiverBob's Avatar
[quote author=cp link=board=20;threadid=16049;start=15#155622 date=1057112928]<br>Bob, I thought you got that fixed? Weren't you the one who got the whole new flywheel, pressure plate, and clutch?<br><br>Some gear trains have a resonant frequency down low that simply can't be avoided. I've had many trucks that would make a racket if you lugged them below a certain point.<br>[/quote]<br><br>You are thinking of Sierra Phil - - he had total replacement. His was more at the engagement of the clutch - - mine is after clutch fully engaged.
Old Jul 2, 2003 | 03:50 PM
phox_mulder's Avatar
Said it before, will say it again.<br><br>FiverBob-SierraPhil<br>Potayto-Potahto<br>Tomayto-Tomahto<br><br>Lets call the whole thing off.<br><br><br>phox
Old Jul 2, 2003 | 07:55 PM
FiverBob's Avatar
[quote author=phox_mulder link=board=20;threadid=16049;start=15#155879 date=1057179036]<br>Said it before, will say it again.<br><br>Lets call the whole thing off.<br><br>phox<br>[/quote]<br><br>AWWWW, Killjoy. :'( But you have to clean up the place. <br><br>PoutAndGoHomeBob
Old Jul 2, 2003 | 08:02 PM
spots's Avatar
FiverBob-SierraPhil
Potayto-Potahto
Tomayto-Tomahto
phox
[/quote]
Old Jul 3, 2003 | 11:31 AM
FiverBob's Avatar
[quote author=spots link=board=20;threadid=16049;start=15#155936 date=1057194176]
[/quote]
And who let you down off the porch, boy? ??? ???
ps: stay where you are for a while - - it's hot down here, baby. 8) 8)
Old Jul 21, 2003 | 01:23 AM
moparman2's Avatar
I see your problem.You need to pull that 16000,not push it. come back
Old Aug 11, 2003 | 01:46 PM
FiverBob's Avatar
Well, attempt #1 to correct the Shuddering Ghost is complete. It now has a new clutch plate. Here are the results:
1) Still shudders when hooked up to fiver
2) The clatter at low rpms in low gears is still there
3) The new clutch does not engage as smooth as the old one - - I am having to learn how to drive it again. (the CFO is now in therapy for whip lash )
The old clutch was like silk - - this one has a tendency to hit pretty hard. That may be a plus - - we will see as it works in a bit.
If anyone hears of new information on the shudder problem or the clatter at low rpms on the 6 speed, plus PM me. Thanx.
SsshhhheeuuudddeerrrriiinnngggBBBBBobbb
reaves11
May 22, 2010 10:24 PM
Rafter B
Apr 13, 2008 09:40 AM
crossy
Nov 27, 2005 03:48 PM
Bobcat698
Nov 4, 2005 11:27 AM
MusicMan
May 11, 2005 07:35 PM
