Shredded Belt
Old Dec 28, 2006 | 07:30 AM
Geico266's Avatar
Originally Posted by Apache1
That business about the truck locking itself while running. I almost had this happen for no reason. Now, I always open my window enough to get my hand through in case it locks when getting out to open gates etc.
Does anyone know why this is happening? Fix?
I would think the dealer could disable the "auto lock" feature. They do it with a scanner type tool and turn that feature off.
Old Dec 28, 2006 | 07:31 AM
usernames_taken's Avatar
Originally Posted by wexman
Dealer said sometimes the shredding is caused by the strain of the belt chirp.
What's a belt chirp? My engine makes a chirping sound sometimes when i turn it off...is that an indication?
Old Dec 28, 2006 | 09:31 AM
wexman's Avatar
Belt chirping on shutdown is NORMAL for all diesel, because of the engine's high compression. It is caused by the engine stopping before the accessories, hence the belt slips and strains slightly on the pulleys.
It seems that on some of the 04s and 05s, there were either sub-standard belts used and/or some may have been installed incorrectly, and/or these engines stress these belts even more than is normal on shutdown.
For WHATEVER the reason, the clutched pulley eliminates slippage of the belt on shutdown, eliminating the chirp, and reduces stress on the belt, which cold help it live longer.
Old Dec 28, 2006 | 09:33 AM
Hercules130's Avatar
I would say that is it. I would get it done just for peice of mind. i didn't have the belt chirp it and still jumped off the pulley.
Old Dec 28, 2006 | 11:11 AM
Is there a recall of some sort? Mechanical/Software? Thanks for the info!
Old Dec 28, 2006 | 02:36 PM
wexman's Avatar
No recall, it's a TSB. And they may or may not charge you - if you go in complaining of symptoms, they might not (at least my dealer does not).
Depends on the dealer.
bannerd
Jul 19, 2011 06:11 PM
whitebuffalo
Sep 14, 2009 09:50 AM
Townsend600
Dec 27, 2006 04:53 PM
bishgeo
Jan 3, 2006 08:38 PM
cumminsboy
Oct 29, 2004 10:33 PM
