Should I be worried....
Old Mar 26, 2007 | 06:31 PM
ryanhockey's Avatar
my check engine light came on today . I have had the truck for a month it is stock, it only has 4700 miles. What could it be??? any ideas
Old Mar 26, 2007 | 06:37 PM
P.J's Avatar
P.J
Use the key "Trick" to check for codes. It's probably something silly.
Old Mar 26, 2007 | 06:39 PM
Lost Lake's Avatar
Key on /off/on/off/on and read the code/s displayed on the digital odometer. Then post back.
When you turn teh key, just turn to the on position, then just back until the lights go off, then on, then off then on. You will see a series of codes. I bet it's NOTHING TO WORRY ABOUT!!!
Old Mar 26, 2007 | 07:42 PM
ryanhockey's Avatar
i must be stupid because i cant get any codes to show up, all i get is the miles and gear selector.
Old Mar 26, 2007 | 07:55 PM
ryanhockey's Avatar
I got it P2509
Old Mar 26, 2007 | 08:12 PM
P.J's Avatar
P.J
P2509: ECM/PCM Power Input Signal Intermittent
I would take it to the dealer on that one. Could be as simple as a bad ground or harness connection somewhere.
t-15 firefighter
55
May 18, 2006 07:29 AM
ecsmickey
Feb 25, 2005 12:00 PM
BigBlue
Dec 17, 2002 05:02 PM
cfm3110
Nov 11, 2002 08:49 PM
